Tank Needed
Shep
Shep of the Dessert
Lleyn Penninsular
Buy or borrow, but i'd like to buy a tank to fit my 88 R100GS Palavalever, i'd like it not to be a leaky pile of shite like i've managed to have, anything considered to get me back on the road quickly or i might be happy to buy something either trick or sexy or both trick and sexy.
The tank i have fitted is not the small one, nor is it the big one as fitted to the basics (i think), perhaps 22ltrs i think.
It has rotted out around the front tank mount, its been bodged once already and I will try to get it welded up eventually.
Shep
It will fit straight on. It just has the flush filler cap instead of the raised twist in one like yours.
Hi shep,
not sure about my subs! will check. If interested give me a call 07887752999. Thanks
yes i'm interested i'll give you a ring tomorrow evening if thats OK?
Looks like there is more than one john taylor on here, sorry!
Many thanks all sorted, picked up the R100R tank today from John:thumb2
Just got to get a cap for it now £70 it appears from motor works:eek:
Right Tanks on, got taps (had to seal with o rings rather than fibre washers cos thats all i had)
The cap arrived, it fits the hole OK but leaves a 1/4" ish hole around the outside, is there a trim to fit or have i got the wrong cap:blast
Shep
Theres a plastic piece that pushes on.
Part number 8. Theres also an O ring (no 7)
http://realoem.com/bmw/showparts.do?model=0486&mospid=51634&btnr=16_0250&hg=16&fg=11
