Hi all, well I got it done
went for titanium brushed błack and I'm very pleased with the end results
it's not jet black as you will see but I think it compliments the various shades of black and dark grey on the bike.
End result.....
Here are some pics of the process for those that have never seen it done
Ready and waiting....
End result again
Hope you like it
now I will just add that the wrap has been trimmed against the weld lines as you will not get an air tight seal over it. That said it leaves an "edge". Now my solution to "seal" will be to get some plasti dip that I'm going to apply all around the edge. They do little pots of paint on rather than spray on. Like the wrap it will peel off if you change your mind but it will tidy it all up.
Jon
went for titanium brushed błack and I'm very pleased with the end results End result.....
End result again
Hope you like it
now I will just add that the wrap has been trimmed against the weld lines as you will not get an air tight seal over it. That said it leaves an "edge". Now my solution to "seal" will be to get some plasti dip that I'm going to apply all around the edge. They do little pots of paint on rather than spray on. Like the wrap it will peel off if you change your mind but it will tidy it all up.Jon
