TDI SHARRON
BAKERMAN
Andover Hampshire, Real ENGLAND
Just given my SHARRON TDI to a tunning company for the day, on the reciept it said engine revamp, what could the have done its MAD, Its going like feck.
I suspect that it really says "remap" but then it's also probably a "tuning" company.
Who did you give it to?
they'll have put a performance boosting plug in box in the engine management wiring.
easy 20/30hp gain :D
BAKERMAN said:
JUST CHECK BILL it says remap your correct, guy called Ray West did it
Hmm....:confused: You're not really into this stuff, are you? Does it says which software they've used, AMD, Jabba....? Which engine is in your Sharan? If it's a PD motor then they might well have flashed the Eprom with the new map through the diagnostic port. If your engine was originally a 115 PD then you've probably now got around 145 to 150 bhp and c. 250 lbs-ft of torque. If, on the other hand, you had a later PD 130, then we could be talking anything up to c. 180 bhp and 300 lbs-ft of torque.
They've probably just welded-up the turbo wastegate,enjoy....should be good for at least 500 miles.:D
ah yes, forgot about the diagnostic port mods. all the rage now i believe.
