TFT time set
brummy bloke
in the middle
How do I set the time to winter time. Every time I go into the tft menu and adjust the time the bugger resests itself to one hour ahead once the ignition has been switched off..probably should have bought a ktm or sommat..
Setting the date Switching on ignition . Call up the Settings, System settings, Date and time, Set date menu. Adjust Day, Month and Year. Confirm setting. Set date format Call up the Settings, System settings, Date and time, Date format menu. Select the desired setting. Confirm setting.
Setting the clock Switching on ignition .
WARNING
Adjusting the clock while riding Risk of accident Set the clock only when the motorcycle is stationary. Call up the Settings, System settings, Date and time, Set time menu. Adjust Hour and Minute.
