TFT Warning Bingo……who has had these….
Gavla04GS
Great Yarmouth
I managed to get these three messages up today….
Any other 5 year old 1250 GSAs doing that?
Of course I started the bike, rode it round a bit and switched everything off for two mins, then switched it on again, warnings all cleared.
Only ever had the emergency call system error when the battery voltage dropped low after failing to start once. The bike did a hard reset and as you say completely disappeared. Haven’t seen it since!
Get her on a trickle charger for the 2 weeks of salt and shite they stick on the roads in the UK 👍🏻
Yep when my battery was on its way out it would throw up all sorts of error messages that had me panicking.
Once charged up they would go away...ended up replacing the battery and not been an issue since so be warned your battery may be on its way out!
Warning noted and it’s been left dormant for too long…..
Some GSAs is well known for having starting issues (look through these threads and Youtube) as soon as the battery is even remotely starting to loose power.
A few of us have swapped them out for the new hybrid battery (AGM and Lithium) which has over twice the cranking amps power
Never had a problem since
I’ve saved yours and Pukmeisters learning (thank you)
