Le singe
The ignition for my carburettor conversion arrived this morning,so that's another item hopefully sorted for the carburettor conversion.
The 40mm Bings are already to be fitted and I'm waiting for a few cable nipples to arrive to make the first throttle cable.
The ignition has a variable limiter plus an advance curve that hopefully won't be a million miles away from the optimum.
Next week,I should be able to visit the dyno for the 'before' curves,then I can start the fitting of the parts.
Just the fuel feed to be sorted,modify the feed pressure of the existing fuel pump to suit the carbs or fit fuel taps?
I like the simplicity of the taps,but the lines of the tank without them....
I've also acquired a spare set of cylinder heads,so should it be bigger inlet valves and ported heads time?
Or,how I think a question concerning modifications should be asked, 'Is there a good reason for NOT modifying the heads while the bikes off the road?'!
It will be interesting to see the photo of all the wiring and components that are obsolete after the conversion.
