Yip mine is still on the original bearing at 77,000 miles. Reckon it was correctly shimmed or it would have gone by now.
Hi Marc it's the big crown wheel bearing which is a caged ball bearing and the inner is a tapered roller bearing. I reckon they fail because there is a turning moment on the rear wheel because of the single sided swing arm. The big caged roller bearing fails most commonly and you end up with a mess like in the picture above.
The old K series bikes had the same set up and rarely suffer from bearing failures. If they do it’s usually at 150k plus miles.
Super Teneres have a similar setup, wonder how they last? Anyway, changing the bearing is pretty straightforward and not too expensive, so why not do it every 40 or 50K for peace of mind?
Sure the Moto Guzzi's of a similar era used the same large bearing and suffered similar failures
This ain’t pretty.
For those of a sensitive disposition, please look away now… This ain’t pretty.
I’ve got the inner race off the hub so now it’s a matter of ordering the replacement bearing/seal and measuring up to check how much, if any, the shims need modifying.
Similar story with the later K’s
Same design (albeit flipped over)as the 1200gs hexhead ,but I probably rebuild 20/30 gs ones for every single k .
I can only put it down to the 4 cylinder motor gives the transmission an easier life.
Jeez, about time I got shot of mine then! It's got 70,000kms on the clock but I've always been paranoid about the FD going on a long(ish) trip. Think I'll stick with my little V Strom.
Cheers,
DickyB
Whilst you have it apart,
Take a proper look at the input pinion bearings,
I know historical advice on here is to just change the crownwheel bearing,but most of the fd’s I look at these days have worn if not knackered input pinion needle rollers.
