Throttle body referb kit
taffyflytyer
liverpool
Any ideas where I get one for 1150 gs and can you do them yourself
If not where can they be done
how do i tell for sure that they need replacing whats the test for this
Start bike, apply pressure on cable pulley wheel with finger, if noise disappears you've found it.
Whether they need replacing is more subjective.
Take a look here: http://www.largiader.com/tech/tb/
My throttle body rattled/knocked really loudly with minimal wear, nothing as serious as this.
:flag
When I throttle off the revs dip below 1000 rpm then slowly rise to 1150 then hunts on ilde will this be the cause (worn throttle body) or is it something else I gave it a good hammering yesterday it pulls well cruised for 90mph for hours but when stopped same thing all the usual has been changed
I had no obvious symptoms when running other than the racket at tickover, but I had minimal wear. Maybe someone else can point you in the right direction.
:flag
