malcolmkaty
Help I have just fitted a cover to protect the sensor but when the two screws where out the sensor it did get turned a bit but the sensor did not get removed ,i have not started the bike yet as the tank is off while i get the plastics painted ,looking in the haynes manual it reads if you disturb it it needs resetting by bmw ,is this the case ,as with the abs bleeding you can do it yourself
Malc
Malc
