Hi folks,I have an r1150gs. I was out for a run today and the bike was performing perfectly normally. I turned on the heated grips and after about 30 minutes I noticed that any time I released the throttle to slow down or to change gear the engine speed did not respond but continued to rev on . Even when I came to a stop and took my hand off the throttle it continued to rev. A short time later I turned off the heated grips and within a few minutes I noticed that the problem disappeared ie the revs would die away when the throttle was released.
My question is this, is it possible when heated grips are turned on that the heat generated can cause some expansion and this prevents the throttle returning to idle.
I know this may sound far fetched but it is all I can think of.
I would appreciate any help offered.
Niall
Niall
