THROTTLE STICKS
Pipster
north west
Throttle sticks when heated grips are switched on,Anyone know of quick fix or am i going to need a new throttle assembly ?
Thanks Phil
It's a common "feature".
Quickest fix - slacken off the bar end bolt a little.
Slightly less quick fix - remove bar end weight and fit an approprately sized washer.
Remove bar end weight place small washer /spacer on the bolt(inside the bars) spacing out the end weight problem solved
