TKC80 tire pressures??
WindyChuffer
Londinium
OK - shod my GSA with some TKC80s at the weekend and set them at the standard 1-up air pressures. Quite a different feel to Tourances/Battlewings. Front seems quite vague and squidgy. To be expected, and just an observation.
Going to experiment with them for a while, and now have 2 x sets of wheels, 1 set with Battlewings.
Was just wondering what air pressure folks on here run TKC80's at when using these tyres on the road ???
Ta
I run mine on 2.5 and 2.9 bar, was two up to GOTC and that was fine. I tend to leave them atthis when solo too and doesn't make any difference to handling as far as I can tell.
2.5 2.9 is the recommended, but I wonder whether that is hot or cold.
Normally cold, can't see why they would change it just for TKCs ...
WindyC, they do feel a bit vague at first, you have just gone from a modern radial belted carcase to the "old" bias-belted type ( cross-ply ). Once you get used to the feel they are much better than you would think :thumb2
2-up 2.5/2.9
1-up 2.2/2.5
Same as Tourances.
To allow for the wife jumping on the back sometimes I leave them in between.
2.35/2.7
