TKC80's plus hugger?
Bubb
Dogsbody
London
I currently have tourances fitted, but want to put a set of TKC80's on next.
The only question I have is will the rear foul my carbon fibre hugger, or is there enough space to fit the TKC's ? ... its a 2003 R1150GSA.
Anyone out there have the ilimberger carbon fibre hugger with TKC's that can reassure me.... or will I have to remove the hugger if I want TKC's ?
Thanks in advance.
Bubb
Thanks in advance.
Bubb
If your fitting the tkc's and using it off road the hugger wont last two minutes with flung up stones. So either stay on road based tyres or bin it...
R.B
Got the Limberger on my Adv, run with TKC's for at least half the miles i've clocked up on GS's over the years, run off road around Devon, Somerset, Yorksha and The Alps/Dolomites and never had a problem.
The important thing is not to go off roading when the trails are soaking wet and clagged up with mud. You'll get all blocked up and those conditions don't really suit the GS either. Dry trails = no problem.:thumb2
