To Vent or not to Vent...
MartinK
Clackmannanshire
Just putting my GS together after having Denz0 rebuild my front shock...
I noticed that the coolant header tank does not have a breather pipe installed, and hence could dump coolant into the area of the front shock, and the top of the motor
Looking online ( https://www.advrider.com/f/threads/overflow-hose-missing-from-coolant-tank.950401/ ) I see that many don't have a waste pipe installed (but I also see a claim that some variants of the watercooled boxer engine do have vent pipes?
Is it worth popping one on? Any views/advice?
Just don't route it so any output doesn't go over your rear tyre as I'm guessing the coolant with antifreeze in it will be a bit on the slippy side?
