jlabro said:tested the bike to GT1 today,and is showed one error to the abs system and one error of "brake liquid too low "
the mechanics there told me that the error from the abs system was as i sometime did not the selftest to complete and pressed the brake (which i can't remember doing it), and about the "brake liquid too low " error, they said that as i fell,this gave the signal .
The point is that the bike never went down by side..it just went into a hole of earth into STRAIGHT position,so i do not believe the are right. The brake liquid now is at the middle,and i believe it should at the upper level,as the bike has only 3000 km .
But i cannot prove anything i guess.. what's your opinion ???
On ABS/Servo bikes the brake fluid should stay at the same level (even as the pads wear down), unlike the non ABS/Servo bikes where the fluid goes down as the pads wear. So if yours was at the upper level prior to the accident something must be wrong with the system.
