TomTom Rider jack plug connection
Greenman14
Gloucestershire
Has anyone out there bodged a 3.5mm jack plug socket onto a TomTom Rider? If it's possible it would let me choose between wired and Bluetooth. Don't tell me I should have bought a Garmin with a jack socket outlet already installed, I already know that!
I wired a jack plug to a car specific tomtom via the external speaker.Seeing as there is no speaker on the Rider,I wouldn't have thought it was an easy fix.
Come on you tech geeks out there:confused:
I know little about either unit, but if the Rider is Bluetooth output only for audio, I really doubt there's any way of 'bodging' a stereo jack into one....the connections won't exist inside :nenau
Seems to me (and this is only a guess) that you will need to convert the BT signal to an audio output, then that to a stereo jack socket.....I've no doubt there are widgets on Ebay for doing exactly that, even if you have to think outside of the box a little and 'miss-use' an existing hardware application involving BT/sound.
Pick out the keywords from your OP and whack them into Google or Ebay search....I bet something will pop up, but Bluetooth signal to jack output without an intermediary device? :nono
There is some form of audio output through the terminals at the back. When you slot Rider into the car mounting you get sound through a speaker in the car mount. This works with Bluetooth off as well.
HTH
Mick
PS. This applies to a Rider 2 unit.
Livin' the dream
Not sure if this helps.
The TT Rider has 4 connectors on the back 2 for power not sure what the other 2 are for.
But the car mount for the TT Rider has a speaker in it and that as far as I am aware is not connected via bluetooth. :nenau
Yes this can be done by wiring into the terminals, don't ask me which pins though.
Cheers, Colin
Cheers, Colin
Speak to this guy EMA Ltd. on 07904 956812. He fitted a 3.5mm ear phone socket to my garmin nuvi for me, I can't rember how much but about £40 and was back within a few days. I hope this helps.
Yes, I use the unit in the car and the mount has a speaker incorporated. It only works when it's connected to a power supply. I guess two of the connections are for a speaker but I can't see how to dismantle the bike mount to get at the wiring. Thanks for replies. I'll post if I find a fix.
A hard wired connection would work much better with the Autocom system I am trying to put together, on a tight budget.
Anyone manage to connect ear phone to tomtom rider
Hi I wanted to invest in a tomtom rider as am hopeless on direction and lost all the time. Has anyone managed to connect their tomtom rider to a jack plug ? I would like it to connect directly to my ears phone rather then the Bluetooth.
Thanks much appreciated,
Emily
