Too wide? Hard side panniers
Jayjayuno
Member
Bristol England
On my GS 1250 TE I have looked at Shad as the already bike came with their fitting kit.
They stick out a mile.
I am looking for some hard luggage with decent capacity that doesn't protrude much wider than the handlebars.
Otherwise lane filtering becomes limited.
Any recommendations?
Aluminium boxes or a Touratech box set up are about as wide as a GS, or there’s the Vario set up without the racks.
I've had SW Motech hard panniers with both their fitting kit and adapters for the BMW OEM racks and in both cases they stick out beyond the handlebars. So I don't think those are a viable option. I'm now using Bumot soft panniers which allow me to still filter.
Buy the biggest top box you can, that way you can make up for the narrower panniers.
i have the Givi outback trekker 58ltr
with Givi Trekker panniers (46 and 33ltr
all Panniers add width but they are practical.
I remove my panniers and frames when I'm not touring, so makes filtering during commutes easier.
So how much wider than the handlebars do these OEM Varios stick out? Interested in the measurement if nayone has them on a TE
At the rear mounting points each of the vario panniers for the LC GS are approx 290mm wide in the unexpanded position so if you measure between the mounting points and add that to the above that'll give you an idea. Mine are in the loft at the moment so unable to try them on the bike.
They don’t stick out as far as the mirrors, that’s the law innit?
Have a look at BUMOT, better quality than the BMW metal boxes imo. They also do a soft panniers but with the hardware to mount directly to their frames. Very good quality and easy to use (roll top and then plastic buckle to hold)
There is often a set for sale on here.
I have these myself and they are bloody brilliant.
I’ve got touratech Zega pro 38 liter boxes, the “special“ with a cut out on the exhaust side
they’re just about as wide as the engine
if the front of the bike goes through the panniers will follow (y)
The Vario panniers are what I have - they don’t even stick out as much as the engine bars (just). You’d still have to mindful if you’re steering through stationary traffic in that you’d be able to cut less of an arc, but otherwise I don’t notice their presence in practical terms
Apart from the fact they weigh as much as if they were made from lead, hold next to nothing, open at the side and disintegrate on contact with the road.
They do look good though, I’ll give you that…
That's probably all true but i still never use all the gear i take. They're just so easy.
