Top Box
r16chh
wales
Hi,
Can someone please tell how the expandable top box expands.
Richard
I am guessing you mean a vario top box, look inside you will see a bar running around the inside of the box about half way up, it will be held in a recess / clipped in place, just grab it and pull it up and over to the other side 180 degrees until it clips into the opposite side, as you move the bar across the box will expand. Also check its not already in the expanded position:augie same operation to contract it only opposite.
This has to be a wind-up, right?
:blast
Please tell me it's a wind-up.
:Motomartin
Before you ask.....
The expandable panniers expand (and contract) the same way, too :thumb2
:blast
:Motomartin
Might it have occurred to you that the fella might 'just might' not have actually seen inside a vario box yet??? :nenau
Why not allow the uninitiated the same chance you where given :rob
Val.
Val.
yeah, but it's still gotta be a wind-up:augie
:D
Thanks to those who gave helpful replies.
You have to understand, I need to ask.
Do you have a GS with varios?
Or you don't have varios, and just info about them?
Just seem a crazy question to me.....but that's just me, maybe:
:D
In this R12GS 2010 review you can actually see how the vario system on the panniers work. The review's in french, but that's not important here. From 2'30" onwards.
http://www.youtube.com/watch?v=sVKwa1xDdfA
I find the varios quite ingenious. When travelling I always leave home with panniers in smallest size for easy filtering, but topbox completely expanded. This leaves room for extra stuff I may bring home.
Cheers, GSband
Gotta say initially i thought "wind up" but then thought if the mechanism had jumped a tooth as mine did a while back the boxes are impossible to expand/collapse.If you find that you are operating them correctly and they still fail to work give me a pm i will tey to give you instructions to strip and resett them.Where in Wales? if not far could take a ride over if not too far and this is the ptob!
must admit, if you look in the top box and don't see that bar to pull up, should you really be on a bike?
Unless you have a GSA and did not know about Vario panniers...
Top box
Thanks again sorted now works fine the reason for asking was the bar seemed quite stiff and I didnt want to force it if that wasnt the way to expand it.
It should not be too stiff.If it is it may well have jumped a tooth.If you can compare it with another one.If it is much stiffer keep watching I may be posting some helpfull info.I'm just having it checked out now :thumb
I have new vario boxand panniers and think it does require a strange ammount of force to vary them. the panniers sort of twist and it is easy to imagine that something is going to break and that it is not a very robust design. my top box also wobbles a bit in its seatings. How tough is the mecanism ? it's all a bit more Hyundai than BMW IMO
The mechanism might seem a bit flimsy. But I've had my Vario boxes (full set).
for 5 years and over 56,000miles of daily use. And apart from a couple of broken cords. They have served me very well.
:bow
I have had two bounce off!Both when only lightly loaded on broken surface(the road to my works) topbox is now pinned on.Two 10mm holes two 10mm clevis pins 4 x 10mm body/penny washers and 2 R clips joined with sone push bike brake cable.:thumb
Just bought a second-hand top box from Motorworks. Bar appears to be stiff compared to my new side cases, especially when expanding the case. Although it still works fine is there a lube one can spray on the mechanism to make it more smoother?
Re-keyed the lock following the thread in ADV. Very simple, only 2 thumblers did not fit. Now it locks perfectly with ignition key.
Does the top of the box look paralel to the bottom when looked at from side s and front and rear?
Luuube?:ymca
I keep my cases well lubed with Silicon Spray. As most of the internal mechanism is plastic. But a squirt of WD40 etc. would probably be OK.
:thumb
