Top dead centre pin
Deleted account 230327001
UK
Anyone got a top dead centre pin for sale or know where I can access one?
In order to remove the timing cover
You don’t need one to remove the front timing cover ..
I was under the impression you do? Could you elaborate please as its 50 odd quid from BMW! Thanks
i've removed many front covers and you don't need to lock the flywheel at TDC... why would you need to ?
Thought I read in Haynes to get the alternator pully off?
Socket on nut, long breaker bar, hold end, turn ignition on, tap starter, nut now loose ( disconnect electrical connector at both fuel injectors so engine doesn’t start) ..
That is a smart way of doing it, indeed :bow
When I had to get the pulley of few months ago (the seal behind needed replacement), I put the gearbox in 6th and had a helper apply the rear brake (turned out quite some force on the brake paddel was nneded). I got the pulley of and also afterwards torqued up to prescibed value, but had a strong feeling that this was not the smartest way of doing it :blast
Anyway to be better equipped for the future i did a search to see if I could fing the blocking pin at a cheaper price that OEM, and I did:
https://q-tech-shop.de/en/p/top-dead-center-locking-locating-pin-for-all-bmw-4-valve-boxers
I ordered that one and suspect it will work like an umbrella, now that I have it I might never need it.... :)
Really great stuff thanks very much for the link!
Thanks I’ll ordered the cheap pin in the link although this is also a useful method!
