Told ya waste of money, should have spent it on Hillcrop................![]()
... yes but I got to play with my toy box all day.Told ya waste of money, should have spent it on Hillcrop................![]()
... yes but I got to play with my toy box all day.... yes but I got to play with my toy box all day.
You mean you found a guinea pig to try it out first............![]()
Tomorrow it'll get stripped down further, getting ready for the Ohlins kit... which should be delivered this week..
bet you swap back in a week
I very much doubt that.
ESA is great when it works. But the standard BMW shocks get tired very quickly. Mine are starting to fail now after only 14,000 miles from new.
Cavitation & heat buildup is ruining the ride. I think my front shock has dumped all its oil anyways, hardly any damping from the front end now.
Will be glad to get a proper set of dampers fitted
Get them changed by warranty first, and then stick your Ohlins on, that way you have a brand new set if you sell your bike.
Yes I thought about that, but I honestly can't be doing with the hassle of waiting, then BMW insisting to refit the new ESA replacements, calibrating it all, for me to then rip it all out again days later. They'll only replace the front anyways, not everything.
Honestly, I'd rather send my old ESA stuff to Firefox Racing and have them rebuild it properly.
My bike then only has to put up with being taken apart once.
What wasn't made clear to me was how the TDC Lockout Tool is used.
Working on the left hand side cylinder, the TDC Lockout Tool needs to use pin 'A'
Working on the right hand side cylinder, the TDC Lockout Tool needs to be reinserted to use pin 'B'
This then correctly aligns and secures both sides at the correct position for valve checking etc.
Just to make a point clear...there is NO use of the "B" pin during valve timing checks on WetHeads!
If you did install the "B" pin, which is only 6mm in diameter, into the 8mm slot in the outer edge of the alternator rotor, then all of your adjustments for the RH cylinder are off.
According to my DVD, the 8mm pin is for TDC, both cylinders, and 6mm for BDC.
This makes sense, as the very same hole is used for both cylinders. The only difference between the left and right cylinder check is that the crank has been rotated 360 degrees.
In the Description just below the video, I've made a BOLD note about my error in the video. Yes, the bolts are supposed to be torqued to 65Nm, not 56Nm as I say. This is also listed correctly in the Torque Sheet in the Description also.
