Torque setting for the rear brake caliper.
There the same as the fronts yes. So yes maybe the same settings.
Sorry for the stupid question Chuffy.....
Front brake
Brake disc to front wheel M8 x 27, Replace screw
Thread-locking compound (Micro-encapsulated)
19 Nm tighten by stages in diagonally opposite sequence
Brake caliper on telescopic fork M10 x 65
38 Nm
Bleed screw in front brake caliper M8
10 Nm
Rear brake
Brake caliper to Final Drive M8 x 25
24 Nm
Bleed screw in rear brake caliper
14 Nm
Brake disc to wheel flange M8 x 15.5, Replace screw
Tightening torque, 12 Nm Additional torque, 30 Nm
Electronic components
Wheel-speed sensor to telescopic forks/bevel gears M6 x 16
8 Nm
Wheels with bearings
Quick-release axle in telescopic forks M12 x 20
30 Nm
Rear wheel to wheel flange M10 x 1.25 x 40
60 Nm tighten in diagonally opposite sequence
RDC sensor to wheel rim
M8 x 25, use thread-locking compound for repair (Loctite 243, Medium strength)
9 Nm
Side stand
Side stand to pivot mount M10 x 1, (Loctite 2701, High strength)
35 Nm
Rear-wheel cover, number-plate carrier
Number-plate carrier to rear frame M6 x 17.5
8 Nm
Rear-wheel cover to rear frame M6 x 17.5
8 Nm
Spray guard to Final Drive M6 x 20 (Loctite 243, Medium strength)
8 Nm
