Time to open a new thread. Following on from my thread about refitting an exchange starter motor to my 2004 Rockster based trike:
I’m totally Flummoxed
Henry and I had a good fiddle with it this morning. With a properly charged battery the bike turned over well, starter working properly dropping down to around 10 volts under load.
Pulled a couple of plugs, sparking well.
Pulled both injectors, plenty of fuel
The bike obviously has compression
All fuses good. No burnt coils to be seen
Issue with the bike started after a very hot ride on Thursday, stopped for lunch
Bike did not restart. I probably buggered up the starter motor in trying to restart it.
So why is the bike dead, it has sparks compression and fuel. But no start.
If the hall sensor had failed, surely I wouldn’t have sparks?
Any sensible ideas.
A bit of background: ultra low mileage trike, very few miles in the last 10 years: it seemed to work fine, but as a precaution I replaced the in tank fuel lines and fuel filter, big O ring on the pump assembly done at the same time. New plugs fitted and valve clearances checked ( very little adjustment required, covered approximately 150 since the work was done.
it’s a trike so local independent workshops won’t touch it and doubtless the same for main dealers.
Thanks for your help guys
Charles
