Touratech hardpart rubbers .what to use?
Colt
West Sussex / Guernsey
I have one of those Touratech hardparts on the wishbone telelever arm.
the rubber? bits have split and fallen off.
anyone found a proper replacement ?
I seem to remember someone using hard rubber bushes from somewhere .maplins?
prefer sensible ideas:D
thanks.
The small solid rubber 'washers' you can buy for the toilet stopcock are a perfect fit. Availble from B & Q etc.
Mike
Mine got lost too. Got 2 tyre valves and cut the rounded heads off (the bit you normally can't see on inside of tyre) and super glued in place. Just the right diameter and fork legs touches them and not the hard plastic. No-one has noticed the difference and still secure after a year.
thanks so far.i thought it was some sort of hardned material .
all that ttech expense and we end up using old tap washers.
perhaps gluing a rubber block would do the job then.:blast
is the 1150 hardpart useless bling or a good preventative item?
Ive seen & used rubber doorstops glued to the wishbone
Not quite touratech but !!!!! :D
I also have a few ballvalve washers in me shed if yer passing Jason
They will degrade with daylight - need replacing ever 50000 miles
HTHY :thumb2
