touratech led tailight
which one do you mean?
I have this and it works perfectly
its a complete tailight,touratech led,works fine but wheh the 12oo does its check,still all ok,then you start the bike and the bulb out triangle comes on,apply the front brake it then goes out and all is ok,strange or what!just thought some of you boys might have come accross this :confused:
they have.. if you do a search you'll find an answer to that.... i would point you too it but i can't be arsed to do the search :D
BUT THE ANSWER IS IN HERE.... and posted not that long ago :D
you should be a comedian :mad: Thanks anyway
TUNED IN said:
it's no easier for me to search that you....
try searching for..... LED rear light panel
Thanks tuned,found it, seems to be a few problems with the touratech one,Will send it back to them when they open and get another one
I had theirs at one time but found it to not be particulary bright. Returned it and switch to Nippy Norman's. Which is great!
