Hi Guys,
I have recently purchased a set of Touratech spotlights on eBay, however, I think the previous owner just cut the cables when he removed it from his bike.
Obviously the instructions doesn't really help with just wires everywhere.
Is there anyone who have done an installation of these spotlights who can give me a simple wiring diagram. I have a centech A1 box, so planning on running it to there and not directly to the battery.
Currently I have:
2 x spotlights each with a red and blue wire (flat connectors) Both also have a brown wire coming from the blue wire that seems to be cut.
1 x switch with a cut yellow wire (assume this goes to the yellow low beam wire)? and 2 blue wires (also flat connectors on them)
1 x fuse holder, but I don't think I will be using this as I will run it to the Centech unit.
Then, I have 2 relays (stuck together with double sided tape). One is a no-name brand and the other a Hella one. I assume the Hella one doesn't work and the previous owner replaced it by sticking another one onto it.
If anyone has a simple wiring diagram, it would be appreciated.
Currently I have:
