TPS Voltage
ThreeDawg
The Highlands of Scotland.
1997 1100GS. Have had the TBs rebuilt and the TPS was removed. After refitting I set the voltage between pins 1 & 4 to 375mv which I thought to be the correct value, but I've seen different ones between 340 and 380 now. Anyone know what's the factory value?
There is no factory value as such because they use specialist equipment to set up the Fuel management and ignition system which DIYers do not possess.
But the general consensus is:
The TPS voltage measured between pins 1 and 4 should read between 0.32 - 0.40 V.
The preferred voltage is 0.36 V. (360mv)
Ian:thumb2
