Podge99 Member UKGSer Subscriber Joined Apr 7, 2025 Messages 5 Reaction score 2 Location Wicklow Ireland Jan 11, 2026 #1 So am removing rear shock to get refurbed. Lower arms to be tightly stuck in place after bolt removal - any tips or ideas to release it?
DrFarkoff Grumpy Ole Git!!! UKGSer Subscriber Joined Jun 27, 2006 Messages 14,269 Reaction score 2,357 Location Islandmagee, Co Antrim NI Jan 11, 2026 #2 Podge99 said: So am removing rear shock to get refurbed. Lower arms to be tightly stuck in place after bolt removal - any tips or ideas to release it? Click to expand... Lower Arms?? Of the shock where it slips over the bushing you mean ?? Taking that it is up on the centre stand Rear wheel in place Top bolt in You could try pouring boiling water over the "Yoke" as it is and then press down on the rear wheel Heat will expand alloy to "loosen" things a bit Rear wheel fitted will stop excessive drop once it departs the shock IF like mine you have a 3 or 4 inch gap under the wheel ?? Put a bit of wood in there to limit travel to a couple of inches!
Podge99 Member UKGSer Subscriber Joined Apr 7, 2025 Messages 5 Reaction score 2 Location Wicklow Ireland Jan 11, 2026 #3 Got sorted - a gentle tap of the hammer and a piece of old broom handle from underneath eased it out
