Tsiklonaut GS pervert UKGSer Subscriber Joined Sep 25, 2004 Messages 3,473 Reaction score 9 Location semi-homeless Feb 19, 2005 #1 Are there some tubeless snow-stickytires available? Or is it possible to put those screws into regular tubeless tyres to make the GS a bit snow-worthy machine too? Margus
laughingBob Guest Feb 19, 2005 #2 I think screws would be much better than nails, they would't get pushed back through the tead. Give it a try and let us know how you get on
Tsiklonaut GS pervert UKGSer Subscriber Joined Sep 25, 2004 Messages 3,473 Reaction score 9 Location semi-homeless Feb 19, 2005 #3 I mean those things: My friend says some estonian fellow makes the tube-type ones, asks about 25£ per tyre. Shoud i give it a try? Margus
richie Registered user Joined Aug 14, 2003 Messages 9,437 Reaction score 440 Location Allihies again.. but off to Asia soon.... Feb 19, 2005 #4 It has been done, but I'm not sure if you could still be tubeless...
Antti Guest Feb 19, 2005 #5 It would be the best way to shoot studs on some knobbie tyre. In Finland at least Kisarengas Oy makes that work. Kisarengas Oy I think it would cost a bit more than that 25 pounds... In my 2v gs i`ve used tubes couple times, with Mitas-tyres. Rimms are quite similar in oilhead so i suppose you could also use tubes. BTW, i happen to have one useless 18" Trelleborg with enduro studs, i would trade it to 17"..
ELIMINATOR Registered user Joined Sep 18, 2004 Messages 6,809 Reaction score 59 Location Hampshire. Feb 19, 2005 #6 Risk analysis, no no no no Buy purpose made items otherwise too iffy. BUT, if you insist, then I would say NO ON NO. iF YOU REALLY MUST, THEN ALSO USE ONE OF THE TYRE SEALANTS. Still say no on no.
