Tubes on a tubless rim... Airheads
Wrigsby1
AB51
Hi all
A couple of sessions away from the 100RT being complete again... All up and running... The rear tyre deflates with a leak on the bead... It didn't initially, then I had to deflate and re-inflate the tyre for something and it started to leak... Then I fixed it largely after cleaning all the crap and duff previous wire wheel work on the wheel bead... Now it's back again... Can I tube it OK on a later type wheel... I have only used tubes on a tubeless rims many moons ago when I didn't really know much... The info on airhead rims seems a bit ambiguous as the earlier rims were tubed anyhow...
Good answer... I knew the HSE gold standard version but wanted the wise experience of the hardened airheaders...:augie
I started doing my own tubeless repairs a decade ago after some of the tyre places either became fussy about doing them or left it to the "lad" to make and arse of...
I know you said you had a leak at the bead but also check the valve stem where it goes tro' the rim JJH
You have to downgrade the speed rating of your tyre by one with a tube fitted so you'll have to restrict yourself to continuos speeds of no more than 130 I'm afraid.
I have used tubes loads in Airhead GS's with out problems
But what i would do is put tyre sealant in
I have done this before on leaky rims on cars and bikes and it works perfectly ( may take a short time to work )
Thanks for the tips guys... I will also try to keep it down below 130mph if possible... But it may be hard...:D
Hi all
It's possibly better that you buy some bead sealer, which you paste around the bead before seating the tyre,
Having said that I have done the tube trick lots of times, it can be difficult to seat the bead sometimes though!
