Sold TUbliss Gen2 Tyre System Kit 18 & 21 Inch
mark71
Braintree, Essex
I have an 18 & 21 inch for sale which as you will see from the photos have never been used, I would like £95 for the pair including postage.
TUbliss replaces conventional inner tubes with a small red 100 psi insert that creates two different pressure zones inside the tyre itself. This enables an incredible 100 PSI of rim protection, increased tyre stability and eliminates pinch flats. In turn, this allows you to run very low tyre pressure for massive gains in traction and a much plusher ride.
Plusher Ride
We all know the harshness that comes when we have to run higher tyre pressure, imagine how much "PLUSHER" it gets when you drop it below the average 12psi mark. Running lower tyre pressure dramatically decreases deflection (aka the "Ping Pong" effect), and allows your tyres to deal with and absorb the small stuff before it ever gets to your suspension.
Lbs Lighter than HD Tubes
The typical weight savings on a rear wheel compared to a standard pinch prone tube is about one pound and can be several pounds lighter than HD, or UHD tubes. And saving weight in the wheels is the most important place to shave weight. It's a difference you can feel as it helps improve acceleration, breaking & handling. Experts say saving a pound of rotating weight in the wheels is equivalent to saving 6-10 pounds of weight off the bike.
No Pinch Flats
By eliminating the tube you eliminate the dreaded pinch flat, forever!
2 Minute tyre Repairs
Without the tube you can now plug tyres in just seconds with standard tubeless tyre plugs (no need to remove the wheel). And sealants are much more effective compared to tubes due to the thicker reinforced tyre carcass. And in the event of major tyre damage, TUbliss acts like a full circumference rim lock allowing low speed run flat capabilities.
Superior Rim Protection
Get an incredible 100psi protection at the rim, where you need it virtually eliminating any chance of damage.
Super Durable
When properly installed and maintained they can out last your bike, much more economical then buying countless tubes.
tyres Last Longer
More traction equals less spin and wear, that combined with lower running temperatures can substantially increase the life of the tyres. Also, the majority of tyres perform better, longer, due to added performance of running lower psi.
