Tyre pressure sensor faulty ?
Santa-2512
Omnipotent one
North Pole
My Front TPS unit is having a hissy fit
First it gave me a low pressure error Red triangle , which cleared on a stop and restart
I checked the pressure and it was on the lower limit 2.2 bar, so i topped it up to 2.4 bar
Coming back from my rents last week i dropped the from wheel into a small pothole and i got a yellow triangle and the reading was 2.5 bar ( so upper limit)
Left it for 24hrs and all was fine
Coming home yesterday, same again 2.5 bar and a yellow triangle ( so a near upper limit warning )
Dropped a bit of air out , all good
The feck me this morning its now deciding 2.2 bar is now too low , it went off as the tyres warmed up , 2.3 bar but returned a fault once i stopped the bike
Can you give them a good talking too with a GS911, or is it a warning that the unit might be on its last legs ?
2011 hexhead 21K
  1. No hissy fits
  2. No yellow triangle
  3. No red triangle
  4. No techno-babble
  5. No batteries
  6. Accurate
  7. No GS911 needed
  8. It's never let me down tyre guage.jpg (y)
Just saying (maybe put one on your Xmas list? :duck:)
@Santa-2512 I would take it as a sign that the battery is low
Interesting, i rode home from work with 2.3 bar showing in the kombi and the red flashing triangle, the pressure went up to 2.4 bar, and still the triangle..
On arriving home i checked the pressure with my uncalibrated pump, it was about 2 bar. Tyre hot.. I took the pressure up to2. 5 bar and hooked up the gs911
All tests and checks came back good, inc battery health
It said 2.2 bar on the front and 3.0 on the rear
I changed it to psi and it said 19 on the front, snd 27 on the rear. Bit low
Ive changed it back to bar, 2.2 / 3.0
Ill let the tyres cool and recheck
which sensors
the tyre temp offset that lies about what the pressure reading really is maybe different between various sensor types...
I found the later 7 digit BT code ones where less volatile (aka lie more)
of course cold vs warm tyres will still get you 0.2 bar increase on your ride home - from say 12 C to warn 45 C tyre temps even with the offset fake the numbers feature they all have
I leave on bar as the gaps from 0.1 bar to 0.2 bar is far bigger than a single PSI (so bar appears to give more pressure stability - as its not really showing the reading) - which is fine 3psi here or there for most drivers / riders can't be felt - but the reading fluctuating, especially on a car where all 4 tyres often read 1 psi different to each other is really offensive
  1. No hissy fits
  3. No red triangle
  4. No techno-babble
  5. No batteries
  6. Accurate
  7. No GS911 needed
  8. It's never let me down View attachment 320201 (y)
Indeed, but how does that fix the yelow and red warnings when i clearly have no loss of pressure?
