RadioActive
One of the front pads on my 1100ABS has worn a lot quicker than the other three. It's got 1mm left whereas the others have hardly worn at all. The pistons all moving alright (easily pushed them back with my thumbs) and the pin is a stainless one and nice and clean. Anything I should check for, or is it just one of those things? Pads are OEM.
I also that I notice that the new pads are chamferred at the leading or trailing edge depending on which way you fit them. Which way is correct?
Chris
Chris
