Urgent - electrical help needed !
  • Thread starter Thread starter guitarman
guitarman
I'm trying to fit a a Motoswitch and the instructions suggest using the feed to the indicator unit.
1) Is that the black box on the right of the fuse box on the 1150? If not, where is it?
2) If it is that box then the wires appear to be bound up in a loom. Do I have to cut the relevant wires out of the loom or is there another "entry point"
Any help gratefully appreciated with beers as appropriate at the hogroast or in the Picos or even a free CD (that's it- I'll never get help now) :D
I'll keep checking the posts or call 07771 736802 and I'll give you my land line number.
Dick
Well, after taking out the fuse box I decided that I'd just have to break into the loom.
Still a few wires to connect but it's sort of sorted.
Dick
I presume you mean an Autoswitch? Yes you need to unravel some insulation under the flasher unit thingy and splice in the couple of wires and pick up an earth. I managed to fit hella ff50's with the Autoswitch and hella relay all neatly in the fuse box.
It's a Motoswitch Dom.
Did you get it sorted Guitarman? I've been down at The Lands End run so didn't see your posting till a few minutes ago. Give me a call on 07867 502815 or 01509 240971 if you are still having problems.
Thanks Rob. My only problem is what I do with the 2 wires attached to the loom for the lights themselves. One is fused and I presume that's attached to the +ve battery terminal but what do I do with the other?
I'll give you a call tomorrow.
Dick +
