Mo-Tech
Greetings,
I want to buy a 1994 R1100GS, it's a used bike, i have no direct experience with german made bike (only used japanese ones so far), so i need experts opinions about it.
The machine has 53 000 km (33 000 miles) on the clock. It has original suspension.
Can you tell anything about the technical status of that kind of bike? I mean the 1994 model specifically - does it suffer any weak points?
As i've heard: after VIN number 311168 improved transmission fitted. This bike has VIN number 0059969R1100GS - as i can see the numbers doesn't match - so it's the bike with the non-revised gearbox? Does the gear box brake down someday?
Also, the owner seemed to remove the "R1100GS" stickers from the fuel tank, i asked if is the bike been re-painted (probably i though because of the bike has been crashed), but owner sayed that plastic tank makes the stickers go bubble so he removed the stickers. Is it true that the plastic tank makes them go bubble?
Also the seat's covers have been put new. Can the original seat cover worn out in 33k miles of rider on it? Or is it possible, that the clock has been turned back judging from the seat's worn-out - i is it possible that the bike has ridden more than acctually on the clock?
Also the rear brake disc has been replaced - is it normal for that mileage?
Would you buy this bike?
Hope you'll find some asnwers for my bit paranoic questions, thanks a lot, Margus
