USB Connection
wheeledwidewebb
I find the business of removing the battery cover to plug the 660 into the PC for data transfer a right pain in the arse.
I must be missing something, is it only me that finds it annoying.
Has anyone tried using it via a BT, acting as a serial port?
Was going to "upgrade" from 550 but don't think there are any advantages.
I tried it....
it would connect then immediately drop the connection and so far have never managed to get it to work.....:confused:
My PC (running Vista) will often drop the connection if I have a microcard in the 660.
No such problem if the microcard is not there.
You can't transfer data to the 660 via Bluetooth.
So what's the problem about taking a waterproof lid off to get to the USB. Am I missing something?
Continued removal and replacement of the cover must eventually cause the seal to be less effective and it is more hassle than the flip-down cover that was employed on the 550.
As for having to remove the battery as well to get at the memory slot - that must have been thought up by a half-wit.
Well....
that was exciting, after removing the cover, battery the micro card putting it all back together without the microcard it connected perfectly then I found I couldn't do anything with it, took it all apart put it all back together ....think I will stick to the USB cable so much easier......:D
