No, they did a water cooled V8 several years ago…..![]()
Several = 70 years ago
It was a 500cc v8 GP Racer
Both of my Yamahas did this. The filler does not allow air to exit the tank efficiently. The fix was simple, I just used a punch to make a couple of holes in the top of the filler neck. This has the advantage of allowing you to get more fuel in the tank.
Don't use a drill as the swarf will go in the tank
And dont miss the punch and make a spark![]()
Well I've found the Mandello's big fault. It is an absolute pig to fill with fuel. Anything but the steadiest flow of fuel into the tank and it's slopping and spitting all over the place. Not quite sure why it does this, some investigation needed. Apart from that....loving it.
A mate of mine has the V100 and finds the suspension to be poor, punting him out of his seat over bumps and not steering very well. He has taken it to Mark at MH Racing for a basic set up and found that the standard settings are way off. The rear shock is pretty basic he reports. How have you found yours? He may have a bad example. Apparently, the MG or V100 forum is full of folk not happy with the stock suspension....
is this the cooking version or the posh one?
You lost your quid. I've had it nearly a year.6 months , tops...£1 down.
You lost your quid. I've had it nearly a year.![]()
Very nice
Didnt the first R1200GS do this I seem to remember from my 04 model (crikey that was 20 years ago)Both of my Yamahas did this. The filler does not allow air to exit the tank efficiently. The fix was simple, I just used a punch to make a couple of holes in the top of the filler neck. This has the advantage of allowing you to get more fuel in the tank.
Yes there was a mod you could do for an extra liter or so. Worked on rt too. JJHDidnt the first R1200GS do this I seem to remember from my 04 model (crikey that was 20 years ago)
Perfect for the Aviator in the familySaw this today .
Very nice
LOVE IT!Saw this today .
Very nice
