Version 8 is out
Postcode search in CN v8
Just spoke to Garmin to check if loading CN v8 on a Quest 1 would allow it to do full postcode searching.
The answer was NO.
The firmware in the Quest 2 is different from the Quest 1 and it is required (as well as the CN v8 hidden map data) to enable full postcode searches.
Bums :( PB
HTB said:
If you buy a Navigator II from BMW, don't you get 'update subscriptions' for free as well as the unlock? If not, I've been misled
BMW is a little different from standard Garmin. If you are smart you will get two versions of the map for free. But not more.
Version 1: Since the unlock code is provided in the box you don't have to register your license at www.garmin.com. Instead you can use the included map v7 for a year or two.
Version 2: When your v7 map becomes outdated you can register your device and get v9 or v10 at zero charge. :thumb
My advice is to wait until v9 before you register. The differences between v7 and v8 are not huge.
