Is the Dakar generally a bit of a vibrator? if you get my drift
I'm noticing it more recently but can't remember what it felt like 4k miles ago when I bought it!!
I'm in need of a new rear tyre but the front still has a bit of life and my pressures are also good.
Could this be the start of head stock bearings
Another quick question
I've done about 2500 miles on my new rear sprocket and its now showing quite a bit of wear already probably halfway through its life!. Stupidly I opted for the annodised type that are not that tough anyhow but just wanted your thoughts?
Jona
p.s - I never alligned the rear wheel with a laser so maybe that could be an issue with both the vibrating and sprocket wear ???
Jona
Also depends where your feeling the vibrations? Might be worth giving the engine bolts a once over to make sure nothing is loose, also to check the steering bearings get the front off the deck, you'll know if they are shagged
) and the bottom shock mount was pretty dry.
, in fact i bought the chain guide from touratech specifically so that i could run the chain looser than the reccomended 50mm.
