Warning light after ABS removal
Hildasay
Shetland
My 06 1200GS is having a servo/ABS removal using the Motorworks kit in a couple of weeks. I know the brake failure light will remain on after this and will need to be blanked or disconnected, but what about the general warning light (red/amber triangle) - will this remain on as well?
Many thanks.
If you have done the servoectomy correctly,
Th amber triangle will light up and then asuming all checks (other than ABS) are ok will distinguish
The red brake warning / ABS warning ( depending on model year) Will stay flashing red & will not extinguish
Be carefull , If you accidently drop a blob of black mastic over the led, when you are cleaning the PCB it can be difficult to remove ;)
