I did a bit of researach a while ago and put an article together It may be of interest to anyone thinkimg of using DOT5 Silicone fluid in their DOT4 braking systemsAs for his assumption that high performance vehicles should not use silicone based brake fluids is complete rubbish Castrol SRF is silicone based, and formula 1/Indie car teams etc use it, I would be tempted to try but £50 per Ltr is a bit more than I want to spend. In addition most European sports car / Hyper car manufacturers use DOT 5.
But for some reason our friends across the pond seem to think that, the older dot 3/4 stuff is better
articles for the e zine
Well I choose Brake fluid! “Why” you say? That would be because for the average daily commuting motorcyclist or a Sales rep or a Mum taking kids to school it’s a total Mystery!!!
Well here’s a try the definitive low down!
DOT = Dept Of Transport (in the Good Old U S Of A) The Higher the number following DOT then the higher the specification (or Boiling Point) DOT 2 – DOT5.1 (Please Note DOT5 spec fluid is silicone based more info on the shortly!)
If you look at your brake fluid reservoir on the top or nearby you’ll see “Use DOT3 fluid only” That will probably be on an older bike (like an 80’s model).
What it is actually saying is:- “That the minimum specification for brake fluid in this system should be DOT3” in reality You may in this instance top up the fluid with DOT3 or 4 OR change the fluid for DOT4 or DOT5.1 Note that is DOT five point one, each of these are higher specification than the original DOT3 fluid
Now All of these brake fluids are what are called Polyethylene Glycol esters basically they are made from a substance very like concentrated antifreeze!
Perhaps that is a clue to why Mechanics (or should I call us technicians these days) and manufacturers’ request that you should change your brake fluid every 2 years (earlier in Servo ABS systems)
No, not enough of a clue? Well read on, the fact is that antifreeze mixes very well with water, that’s its purpose, for the brake fluid to replenish the space that’s left as your pads wear down there must be an allowance for air to enter.
If, Air can get in? Then so too can water (carried as vapour in the air) water can also enter the system by a process known as diffusion where water creeps in through rubber seals and hoses (this happens over a long time)
As the amount of absorbed water increases over a time period your clean and fresh “golden” coloured brake fluid will turn to a brown contaminated liquid that’s is not very good at dealing with the high temperatures created whilst braking, bear in mind the difference in efficiency shown for just 3% of water absorbed (wet boiling point)
...........Dry Boiling Point..................Wet Boiling Point (i.e. 3% water)
DOT 3............205ºC ...............................140ºC
DOT 4 ............230ºC ..............................155ºC
DOT 5 ..........260ºC ...............................180ºC
DOT 5.1 .........270ºC ..............................190ºC
Also the brake fluid develops slightly corrosive tendencies’ and your systems seals will degrade!
So folks now you understand why we ask that you change fluids etc every 2 years!
It is Not because we get more money from you instead it is the simple fact the fluid doesn’t do it’s job anymore!
Now back to DOT5 spec This fluid is a silicone based brake fluid and under NO circumstances should it be used in a Standard DOT2, 3, 4 or 5.1 system. Or mixed with any of these Brake fluids) AN agreement was reached that silicone brake fluid be coloured “Purple” to prevent mixing with standard “non silicone” brake fluids
A few people are probably thinking “That is great! If I use silicone fluid in my bike it can’t absorb water and I’ll have good brakes!”
Wrong for the following reasons
Silicone based brake fluid is ONLY half as resistant to compression as Polyethylene gycol Hence you will experience longer lever or pedal travel to gain the same brake effort! In other words your brakes will be spongy! ALL of the time! Another note Some Harleys use this stuff as standard Need I say more?
Silicone Brake fluid will NOT absorb water under any circumstance; the water therefore must collect at the lowest point as it is more dense than the silicone. The lowest point is your calliper.
Water boils at 100ºC, the temperatures that can be created by a long drawn out braking manoeuvre will exceed that 100ºC quite dramatically so the water turns to steam and further reduces your braking capabilities.
In fact they will probably not work at all!!
Never Ever use silicone brake fluid in a braking system that it is not specified for! The silicone used attacks the standard seals used in a regular Polyethylene glycol system but at least it’s purple and you will see it leaking out??
