Camel Toe Registered user Joined Dec 16, 2009 Messages 608 Reaction score 1 Location Sheffield, England Aug 18, 2016 #1 Guys a friend of mine has a 2002 650 which is leaking water from what appears to be a hole in the water pump casing... any ideas....
uncle dick Well-known member UKGSer Subscriber Joined Oct 4, 2009 Messages 1,553 Reaction score 3 Location Devon, England Aug 18, 2016 #2 Plenty of info here: http://faq.f650.com/FAQs/Water_Pump_Seal_Repair_FAQ.htm#Symptoms and Mileage
Camel Toe Registered user Joined Dec 16, 2009 Messages 608 Reaction score 1 Location Sheffield, England Aug 18, 2016 #3 uncle dick said: Plenty of info here: http://faq.f650.com/FAQs/Water_Pump_Seal_Repair_FAQ.htm#Symptoms and Mileage Click to expand... Thanks very much...very helpful.
Dansin Registered user Joined May 4, 2007 Messages 2,957 Reaction score 1 Location Ombersley Aug 18, 2016 #4 Water pump seals have failed or shaft is worn. More info here - http://www.f650gs.crossroadz.com.au/WPumpRepair.html
RPMDAKAR Well-known member UKGSer Subscriber Joined Jan 21, 2016 Messages 543 Reaction score 23 Location Bewdley, England Feb 12, 2017 #5 so easy to do Even I managed to sort this one, only headache was when removing the clutch cover to remove the oil pipe to the top end, cut it in 2 and seal with a std compression fitting.
