Wedgetail ignition
The one that I had on my 1983 r100rs was great it made the bike start better but idle was smoother and the general power curve felt more robust
The only problem I had was the mounting of the ignition control unit it now seems that I needed to to drill a hole to make mine fit and I wasn't happy doing that beside the amplifier
So I move mind I'm on top of the airbox and made a modified bracket and vent to direct air to keep it cool
I would definitely recommend them
Motobins is UK and EU distributer.
Give them a shout.
Give them a shout.
Thanks I made enquiries.
I have had an email reply that shipment of units from Australia is still in process but hopefully only weeks away.
Gerry
I fitted a twin plug version they make. very pleased. the amplifier has a larger heat sink so i mounted under the rear tank mounts on my RS. The exixtin rerouted cales fitted.
I have had an email reply that shipment of units from Australia is still in process but in a container on the EverGiven (remember her), now docked at Felixstowe.
Gerry
Fixed that for you :D
