I've spent hours today cleaning my 1150 RT (ABS/SERVO), fairing off, good old spray of Muc-Off, good scrub, hose down and spray of WD-40 before putting it all back together.
The bugger would not start
It did eventually start after loads of attempts and I let it warm up and then checked the brakes, all OK.
But now when I put the ignition on every now and again the fuel pump primes then primes again, then again, then the rev counter jumps a bit, all without trying to actually start it
All sorts of noises coming from under the fairing.
It was running fine last week so something has happened with me cleaning it, do you reckon I should put it down to excess water and let it dry out or have I fecked something?
Update: Just tried it again, fuel pump primes and the starter turns but the engine won't start now
Battery is OK by the way.
