GBH
New spokes wheels have right angle metal valves mounted on the rim. And I have not seen any loose spoke on my 1250 yet
It's not semantics - there is a force towards the centre of rotation which causes the continual change of direction of an object moving in a circular path. Centre fleeing, which I believe is what centrifugal means, would be the correct name for a force acting outwards from the centre of rotation if such a force existed, but it does not.
Centripetal force is the inward force. The effect of the outward force is called centrifugal force (though we know it doesn’t really exist).Centrapetal force is what your looking for...
A centripetal force (from Latin centrum, "center" and petere, "to seek") is a force that makes a body follow a curved path. Its direction is always orthogonal to the motion of the body and towards the fixed point of the instantaneous center of curvature of the path.
Quote on Page 183 of R1250 GS Adventure Riders Manual:-
"WARNING Tendency of valve inserts installed vertically to open by themselves at high riding speeds."
The force towards the centre isn't caused by the rotation, it's caused by GRAVITY.
How does any of this work, if the Earth is flat ?I didn't say what the force towards the centre (centripetal force) was caused by, just that it exists, unlike the imaginary centrifugal force.
I suppose in the case of the earth orbiting the sun you would be correct to say the force towards the centre is gravitational attraction (though let's not get into exactly what that is!). In the case of a rotating wheel I would say that what stops bits of the wheel rim flying off at a tangent is not gravity but the restraining force exerted by the spokes linking rim to hub - at least until they fail!
Sent from my SM-G925F using Tapatalk
Parallel universe is twisting gravity; or to quote Scottie;
Yah cannae change the laws of physics Capn
The reason the valve doesn’t let air out is coz there’s a spring in the valve.
Nah, it keeps the dust out.I'm sure the valve dust cap might have a hand in keeping the air in too.![]()
You could not be more wrong. You could try, but you would fail.The force towards the centre isn't caused by the rotation, it's caused by GRAVITY.
I am just about to pick up a R1200GS for my missus, and I noticed this pin, can anyone tell me what it is for?
I can handle being wrong, unlike many of the flat earthers on the site.You could not be more wrong. You could try, but you would fail.
