^^^^^^ I doubt whether it would add much crash protection as the part the OP is referring to is *inside* the valve cover!
Having also done a valve job on the 1250 I’d also like to know what the function of this part is.
After reflecting on what has since been written regarding my text, from today forward I will stop relying on Ai to give me facts. Instead allow those with actual knowledge to best judge the correct information to be placed for others to read.What It Does
- Prevents Component Rotation: This internal engine bracket or guide mechanically locks specific internal valve-train or cylinder head components in place. It ensures they do not twist or migrate under intense vibration or high RPMs.
- Supports ShiftCam Technology: Because the R 1250 engine dynamically shifts its intake camshaft to alternate between partial and full-load cam profiles, these structural retainers maintain strict alignment of the variable valve timing mechanisms.
- Works in a Pair: The right cylinder head requires this part (11128393674), while its corresponding mirror component on the left cylinder head is part number 11128393673
I agree with that, you have to take what info is returned with a pinch of salt.After reflecting on what has since been written regarding my text, from today forward I will stop relying on Ai to give me facts. Instead allow those with actual knowledge to best judge the correct information to be placed for others to read.
I relied on Ai to only give me correct information, trusting on a good out sourcing of reliable information, but the tools are only as good as the user (me) So I bow to those with greater knowledge and wisdom. I will refrain from using Ai again in attempt to assist users, but giving the wrong information was never my intent........I even asked Ai for an explanation.
Ai says, "Common reasons for AI providing incorrect information about automotive parts include poor data quality, biased algorithms, and limited training data. These issues can lead to unreliable outputs and mistakes in identifying the correct parts".
Therefore I have sacked Ai from any further input, until it gets better data.....the end!![]()
I certainly wasn’t thinking that, I just couldn’t see what it did.Funny though that the shop i do trust, gives a different part no.
https://www.motorworks.co.uk/catalogsearch/result/?q=+Twist+protection
But think we know what they do and they need putting back and not binning if that's what @BillWright was thinking![]()
That was my initial thought. Then I thought why, when the engine sounds like a bag of violently shaken nails on a good day.I don't know, but if it's just a bit of rubber, sandwiched between the head and cover, could it be for sound/vibration damping?
