snoopy
Alu panniers are £160 from eibcltd.co.uk for both. It then costs £250 for the brackets which is crazy.
Andy
Andy
snoopy said:H&P Panniers work out at over £500. Might as well go for touratech ones at that price.
sniper said:Trev, i think all H&B's look like that![]()
Keith Chapman said:I am using the system cases, but what I would like are a set of ally top loading cases that are as easy to remove as the system ones. Ally cases make great camping stools but it is a PIA un bolting them to take them of the bike.
Tho i expect the touratech bits will take longer
rc mad said:bought a set of Caribou Luggage for my 650 (basically peli cases complete with a mount system and locks) I've had to import them from the usa tho![]()
Total cost worked out at around £460 not including uk import tax![]()
I would have bought the ally ones but i prefer the look of the peli cases
Hopefully they'll arrive sometime this weekTho i expect the touratech bits will take longer
). I had to do some minor adjustments to the lower front mounts on each side as there was some misalignment. Once adjusted (it's stated in the instructions that this adjustment may be required) the cases go on and off smoothly and quickly, around ten seconds a side will see the case fitted and locked in position. Simply locate the cases on the rack and turn the key lock, all done from the outside. No faffing around inside the pannier - great for packing in the house then just chucking the cases on the bike.
(at the bottom of phoenix parkway in scunthorpe, just in case the person posts on here)
Modified BMW alloy panniers .... great
T'is a recognised fact that you will fill all available space
T'is a recognised fact that you will take too much
These are ideal for me
http://www.ukgser.com/forums/showthread.php/416066-Pannier-Porn?highlight=Pannier+porn
