I think that its a basic 12k check. So...
Performing vehicle test with BMW Motorrad diagnostic system
Oil change, engine, with filter
Oil change, rear wheel drive (every 2 years)
Checking valve clearance
Replacing spark plugs
Replace air filter cartridge
Visual inspection of the hydraulic clutch system
Visual inspection of the brake pipes, brake hoses and connections
Checking front and rear brake pads for wear
Checking front and rear brake discs for wear
Changing brake fluid, front and rear brakes
Checking coolant level
Checking ease of movement of side stand
Checking ease of movement of centre stand
Checking tire pressures and tread depth
Checking lights and signalling equipment
Function test, engine start suppression
Final inspection and check of roadworthiness
Setting service-due date and service countdown distance
Checking battery charge state
Confirming BMW Service in on-board documentation
I did my own 12k this year and though I would not use the word 'doddle' it wasn't as bad as I thought. My outlay was Fluids (Engine Oil, Final Drive and Brake fluid), Filters (Air and Oil) Pads and plugs. Pads on reflection could've lasted another year.
