Roymondo
Any idea of the length? Would 30mm be about right?
Can you not simply measure across that part of your gear lever with a ruler? It's about 20mm on mine (2011 GSA).
It's M6 x 16mm pan head T30Torx
Actually cheese head, as the sides of the head are parallel, but a pan head would do the trick.
Like I said, put a drop of loctite on to stop it happening again or, you could add a nylock nut, in which case you would want an m6 x 20.
http://www.orbitalfasteners.co.uk/e...button-screws-stainless-steel-a2-304-iso-7380
88p.....
And they will sell you one bolt....
inc. VAT
£8.83
See post #19 Bear. Only the upper section of the hole is threaded. Putting it in from the top won't work as it wont 'pinch'.
Stick it in from the bottom with a drop of Loctite (other thread mangling compounds are available).
Erm.........you never really got to grips with that pesky old decimal point, Did you Twizz![]()
Ok, ive solved my problem. The M6 torx bolt does work as suggested when inserted from the underside, I just wasn't tightening it enough to clamp the peg in position!
Thanks for the help.![]()
Yes I did, but I never tightened it up properly and it all collapsed![]()
