Where do I get my 1150 serviced?
fatnfast
SE Kent, England
My 1150 is due its 12000 miler, where do I get it serviced? I used SPC over a year ago and they seemed pretty good, but have been reading conflicting stories about them now. They also want £20 for a loan bike for the day! What about North Oxford BMW? These are my nearest dealers so its between the two, any feedback would be good.
Andrew Sexton is based near you – just outside Banbury IIRC. He’s one of the top airhead people around and last time I visited he was working on a few oilheads. Could be worth tracking down and having a chat.
DIY - after seeing Noddy service his 1100 last Saturday I'm going to look after my own servicing and save myself quite a few quid thanks very much.
Call it £50 for the bits and pieces for a 24k compared to £200+ at the dealer.
More tokens to spend on essentials
Be wary if it is still under warrantee, if you make a claim and the service was not carried out by BMW you may not have a leg to stand on.
the gs is still under warrenty, so I need to take it to BMW, as an engineer this is frustrating, but I have no choice. If anyone else has any thoughts on SPC or North Oxford, please let me know.:(
Warranty isn't an issue for me so I'm looking forward to getting my hands dirty :)
North Oxford
I've used them quite a few times, the people are really friendly and the service is good. Alas it is a main dealer, so the prices are often ridiculous. Don't even ask for a price on tyres!!! I kept mine going there for the warranty, but you only have to have it servicing etc to the same spec as BMW.
I happened to have found a new guy in Shipston on Stour (30mins North of Oxford on the A44) called Mike at Robsom Racing 01608 664122. He knows what he's doing, and is now offering discount for all UKGSer's on everything from parts to servicing.
Also there is another chap that does only BMW's near Chipping Norton. apparently he's been doing business since the stone ages just on BM's.
When I spoke to him about servicing, he said he has no fixed price like dealers, as he checks everything and will only charge for the parts and time that need doing!? So every service is a different price.
Hope this is of some help,
Thanks SCUD, this is exactly what I was after. As soon as the warrenty is up I will do most myself.
Do it yourself.
The 1150 is a remarkably simple bit of kit, and it's easy to service.
You will find lots and lots of useful info on this site.
Only special tool that may be needed is an oil filter wrench - the oil filter sits up in the sump and is almost impossible to remove without the specal tool.
You will have to remove the bashplate - best to soak all the nuts and bolts in WD40 first.
Do warm up the bike prior to draining the oil.
Do give the oil plenty of time to drain - I pleave it on the sidestand for 10 mins, and then lean it against a wall the other way for 10 mins to completely drain the oil in the heads.
Which oil? As I've already said, the GS is a simple bit of kit, and can literally run on extra virgin! It doesn't demand synthetic oil- it's a luxury. At 12.000 miles, I'd stick with non-synthetic for another service to ensure the bike is fully run in. I use a good quality mineral 20w50, as reccomended in the manual - it runs much smoother than the 10/40 when it's hot. A good tip here is that Tescos sell their own brand of oil which has all of the correct ratings (SJ rating) and is really cheap (£3.00 a gallon!)
Plugs. These are fairly easy - remember to use the tool in the toolkit that came with the bike to remove the HT lead. Many socket-set plug adapters will get trapped in the head - stick with the bike's toolkit plug spanner.
Which plugs? I've stuck with the standard BMW Bosch plugs, but recently, I've seen there are a few threads that reccomend a champion EON2 plug - These may well be worth a try - especially at the price.
A tip here is to put a little smear of copper grease on the plug threads. (Just a little - don't get it on the plug tip or insulator.)
Valve clearence. This is an easy job - follow the workshop manual, and you can't go wrong.
Tips -
DO keep everything spotlessly clean - this is inside the engine, and ang grit will play havoc.
Do change the spark plug hole rubber gasket - only a quid or two, but these do tend to go.
Inspect the rubber valve cover seal when you take it off. Only re-use if it is in good condition - replace it if you have any doubts.
When refilling the oil -
Do use a new sealing ring on the drain plug.
Remember to let the oil settle - These boxers are buggers for holding oil in the heads. You can use the trick of leaning the bike the other way to help drain all the oil into the sump to get an accurate sump contents reading. Be very careful not to overfill.
Gearbox & bevel box oils - These are a doddle - simply remove the drain plugs, and let the oil drain. Remember to use new sealing rings on the oil drain plugs. Fill to level with reccomended oil - again, you will find info on gear oils on this site.
Air filter - easy job - under the seat, undo the cover and replace air filter. While you are there - change it for a K&N or similar.
The remaining items are very straightforward - check battery level, lights, brake pads, tyres etc etc.
If you want to start balancing the throttle Bodies, then there's lots of useful info on this site.
A good tip here is (if you can) be prepared to step away from the bike and come back to it later. Don't do this just before a weekend away - take your time, and don't be afraid to ask someone.
If you need any advice PM me.
thanks for the info Captain B. I used to have an old K100LT some years back, so am hoping the filter wrench is the same (I new their was a reason why I hoard everthing!). As I said, this is my last 'warrenty' service, so after reading all the good stuff from you guys, I am now armed with the haynes manual! I have rebuilt bikes before, part of the attraction to this bike was its relative simplicity.
Has anyone had any dealings with Cooper @ Reading for servicing?
I'm faced with £20 for a loan bike from SPC, or £5 train ticket from British Rail. (Baingstoke to Reading)
I just find it funny when told when buying the bike from SPC that a loan bike would be free (just like the extra long test rides) but when it comes to actually doing the service, they want money for a loan bike. I don't mind the charge per se, it's the principle!
Totaly agree, they never used to charge £20. Its not like a service only cost a few quid. I have mine booked in at SPC now and will let you all know how it went after the service.
