Cheers Mistacat,what else can you use the wake up tool for
Cheers Mistacat,what else can you use the wake up tool for ����
At that price it does not need to do anything else.![]()
If the bike has not been used for a while in winter I sometimes use the wake up tool on both wheels rather than using a tyre pressure gauge.
Saves crawling around on the astroturf in the bike shed.![]()
I have tried everything to test them off the wheel , even made
a jig to spin them up in the lathe.
The only thing that I have found that wakes them up off and on the bike is the Chinese wake up tool, see picture.
Also on ebay
https://www.ebay.co.uk/itm/14400071...77DNYji+d3q6lwjuXK2ev6qZWk|tkp:Bk9SR77WgOXlYQ
[/IMG]![]()
Baza - if you don't have the wake-up tool and GS-911, you can do one wheel at a time, but go for a ride between times until the wheel you have just done is recognised by the bike. i.e. do one, change the battery, put it back and ride until the bike "sees" the tpms sensor, then do the other one. There are many reports of this working just fine. Worked for me a while back! If you replace the battery in the tpms, the bike would hopefully "remember" the last setting...
Must be someone local (Merseyside) on here that has the wake-up tool? I have one I would happily lend but I'm at least an hour away.
It's something you don't use often! Maybe 3 or 4 times in 5 years for me.
All you need to do is hold the tool next to the sensor, and within a couple of metres of the bike. When you turn on the ignition the bike should "see" the sensor. That's what happened with my new 3141m but I did have the GS-911 plugged in, which "saw" the sensor via the bike![]()
Didn't the tyre pressure come up on the dash as 0 PSI? Mine did (but mine's a later 2018 machine). The dash recognised the sensor on the dash once the wake-up tool had woken the sensor...
I’ve done the holding it close to the sensor,the funny thing is I drive a 66 plate CorsaYou have to hold it against the tyre as near to the sensor as possible.
You could try it on a mates bike if the bike has been stood for 15 minutes switch the ignition on and go through the menu with the info button until the tyre pressure page, then see if it wakes his sensors.
Vauxhall and GM cars are also on the same 433MZ frequency. probably loads of others ??? someone will know.
Ibex - you are relatively local, you can borrow my TPMS "wake up" tool if you like, assuming you have a GS-911 to reprogram your bike, or just change one sensor at a time and go for a ride inbetween!
I also have a "spare" rear wheel with a 3141M in it, you could try and make sure your bike will recognise a 3141 (asuming you have a 911). Obv the wheel won't fit, but your bike should recognise the 3141 if held close enough to your bike with the wake-up tool and 911
The wake-up tool works by sending a 125 KHz signal to the sensor that wakes it up.You have to hold it against the tyre as near to the sensor as possible.
I have actually bought a pair of sensors direct from Schrader having been told that a lot of the cheap and cheerful sensors wont talk to the BMW technology! The sensors were half the BMW cost but still hit me for £185 for the pair! Sadly my friendly tyre fitting chap doesn't have the correct bit of kit to get the new sensors to work on my bike! For some reason the £5k bit of kit he has works on everything BUT BMW bikes! So now I'm stuck with a flashing red warning light on the dash telling me my tyre pressures are 0.3 bar.
What's the best bit of kit on the market for a private individual like me to do this without troubling Mr BMW?
